| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
#1 | ||
Rep Power: 10 ![]() |
That is correct.
#2 | |
IT'S ALIVE!
Rep Power: 17 ![]() |
![]() I want to do something like this, but with the stock hub bore and I'm running into an issue - the ID of the spacer must be 59.6mm to accept the stock hub and the OD of the spacer hub must 59.6 to work with my current rings. The ID of the spacer needs to taper or step down to like 54mm or something to allow for material to be machined off to make the OD of the hub feature 59.6mm. I currently do not know what the "step" height is on the factory hub, which is needed so I know where the ID can step down in size (I think it's like 5mm or so). What necessitates the need for the removal of the hub for longer studs? Is there just not enough spacer to feed the longer studs through the back when it's assembled? Oh yeah, I corrected the first drawing. |
