Old 04-01-2010, 11:55 PM   #1
sen2two
KTEC
sen2two's Avatar
Originally Posted by Max777 View Post
Ok, a boost drop makes sense. Would installing a boost controller fix the problem? A garret wastegate, depending on price, doesn't sound like a bad idea.
11PSI? I have a 255lph pump, 750cc secondaries, and an RTEK 1.7 ecu... can I run 11psi then? My gague only goes up to like 6~8psi max right now.
A boost controller would make absolutely no difference at all. And given your upgrades surpass mine, you should be able to handle 11psi just fine. But to be safe, check it with a wideband to make sure your not leaning out or get some minor tuning done. an safc2 would be fine in your case...
what I have:
What I had:
Old 04-02-2010, 05:30 AM   #2
NVM
Old 04-03-2010, 06:53 PM   #3
Really? I thought that it holds the boost from opening the wastegate untill pressure reaches 11psi, therefore boost should not drop as much?
Or am i missing something here?
Have you tried using one to see what happens?
