#33 | ||
frustrated!
Rep Power: 17 ![]() |
I thought about that BUT my main concern of mounting the nozzles farther down stream from my TB is being located before my damn relief valve. If I ever overboost I AT LEAST want my 50/50 mix still supplying the motor under these brief severe conditions...again hypathetical but at least some what safer then high boost with no WI That is one of the main reasons I do not want to go pre-turbo. However I do hope that the nozzle location in my prev picture is far enough away from the rotor chambers to let the meth "flash" with the water/air....My last concern is going to be how to mount the 2 nozzles. I was originally going to mount them 180 degrees from each other BUT after reading some of Howard Coleman's posts, the 3 and 6 o'clock positions seem the best. Anyone have any input on this? BTW, snow performance contacted me and told me that there is only a 5PSI differance in pressure at the nozzle of 2 175ml/min nozzles compared to 1 375ml/min nozzle. hmmmm, still.. slightly better atomization with 2 nozzles. Quote:
Same pig, new soul
