Old 02-28-2010, 04:58 AM   #1
KaiFD3S
KaiFD3S's Avatar
90mm Rotary-Works TB
Just received my 90mm Rotary-Works TB such a great piece can't wait to install it and test it, too bad it will be a while since the car is still hybernating.
And I thought I was done with this car...LOL..
Here some pics
RE AD FACER 9
Old 02-28-2010, 07:53 AM   #2
COOL!
Can you still use the Stock TPS?
Old 02-28-2010, 11:03 AM   #3
KaiFD3S
KaiFD3S's Avatar
Yup stock TPS works with this
RE AD FACER 9
Old 02-28-2010, 02:11 PM   #4
KaiFD3S
KaiFD3S's Avatar
Here more info on it Phil, sorry its from the other forum..
More info here with some video of it
http://www.rx7club.com/showthread.php?t=877729
Old 02-28-2010, 07:58 PM   #5
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
I might be installing one on a car here. A lot of throttle bodies are just straight worn out. I am also curious to see how well the shafts seal under higher boost levels..
1Revvin7 is offline   Reply With Quote
Old 02-28-2010, 10:15 PM   #6
Somebody PM them over there to come join us here!
Did you guys read that whole thread??? They make some great parts, and priced extremely well.
Old 03-01-2010, 01:16 PM   #7
Rotary-Works
Rotary Vendor
Rotary-Works's Avatar
Rotary-Works is on a distinguished road
Thanks for the great feed back.....we just opened our new website check us out.
We will have more parts available soon more pictures and Videos....
Thanks
www.Rotary-Works.com
www.Rotary-Works.com Now Open!!
1qwkrx3@gmail.com
Rotary-Works is offline   Reply With Quote
Old 03-10-2010, 08:41 AM   #8
Thanks
Welcome to the site!!!
I have a question about your "CNC Cut Billet Aluminum Throttle Body for 20B 3Rotor".
I'll be doing an 20B swap into a 3rd gen. Would this work with 3rd gen TPS and 3rd gen throttle cable?
Old 04-07-2010, 01:58 PM   #9
papsmagu
papsmagu is on a distinguished road
yes it does, i am currently running one on my fd. the only thing i had to do is re-position the throttle cable support bracket. everything else lined up perfectly.
the TB greatly improved the throttle response on my car. it drives like a different car now! no hessitation at low RPM's as you may expect from a 90mm TB. i run a single turbo not twins.
papsmagu is offline   Reply With Quote
Old 03-09-2010, 10:13 PM   #10
Double_J
Double_J is on a distinguished road
Put it on and let us know how it is!
What other engine work have you done to the car?
Double_J is offline   Reply With Quote
Old 03-11-2010, 05:21 PM   #11
allrotor93
allrotor93 is on a distinguished road
They said they would do a group buy if we got some interest...I would buy a 20B unit
Hey Phil,
You want to set up the GB?
allrotor93 is offline   Reply With Quote
Old 03-16-2010, 03:43 PM   #12
David Jerome
David Jerome's Avatar
Id be in for a group buy. Let me know the prices. 13b-rew of course Im not a balla yet with a 20b.
Old 04-19-2010, 04:07 PM   #13
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
i really want to see before and after dyno results on this thing.
Old 04-19-2010, 04:58 PM   #14
OK, I'm going to contact them about a GB. I'll post up!
Old 04-19-2010, 07:04 PM   #15
MotoTek
Always Under Construction
MotoTek's Avatar
phil, pm me if you get things set up, I'm down for one.
BLACKADDE™ | ADGT RX7 |
