Old 03-27-2008, 02:47 AM   #1
One wire is used as a voltage input for the internal voltage regulator.
I believe the FD needs a constant +12VDC.
This needs to be connected.
The other is for the warning light.
It triggers a signal to the warning light cluster to tell you there is something wrong with the (electrical) charging system.
This doesn't need to be used.
