Rep Power: 10 ![]() ![]() |
Just got my car deflooded..
Now I understand about why some HATE 8's!! Yikes! It took me 2 hours to deflood.. I finally did it by replacing the sparks and doing the FUEL PUMP FUSE thing.. Its not the BIG BLUE Fuse that says, "FUEL". Its the Tiny 20A (yellow) FUEL PUMP Fuse.. After having my wife's MX5 jumped to the 8, I was finally got the 8 Started.. I would NEVER shut this FUCKING car down when its COLD! I even rev'd it up before shutting down and did this..
KONI Challenge Crew
That's just a wives tale...if anything that's probably what caused the flood. The '04s did have a problem with "warm" flooding...it happened to me after a very spirited run on some back country roads once. But if I were you I'd take it in to the dealership and make sure all the flashes have been installed. There is a flash out there that helps against flooding. My car has yet to flood since I got that flash and I've tried to flood it! HAHA!
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
#3 | ||
Here are what the sparks look like.. Quote:
