Old 02-07-2010, 02:25 PM   #1
Originally Posted by SportTuner.com View Post
Yes that will happen. It is the pigment in the coating that doesn’t handle the heat and will fade to a degree when you heat it. This is a common and know side effect which I have yet to find a solution to solve. The ceramic media is not effected just the depth of the color. Some colors will fade less than others but will have a lower heat threshold.
Yup, you even pointed that out before I sent you all the parts, that while the color may change over time and heat cycles, the thermal barrier won't.
Just incase anyone is wondering, as no-one has posted pics of Anthony's products yet, I'm sure a bunch will be posted when he gets setup as a vendor, but let me toss some up now.
Here's all the parts that Anthony coated.
You can see the difference in the powdercoating that I did and the ceramic coating that Anthony did. I'm going to try a new powder, if I can't get them to match, Anthony will be recieving everything else so it all matchs all nicey nice.
-Brian
