Show your rotary car build up. Show off your Rotary Car build! |
#16 |
Our goal is to make it as easy as possible to bolt in a Rotary Engine at a reasonable price. Ricardo will be making the engine mount bracket and he also does custom work for Kilo Racing and he wants to make it good quality.
Jimmy FujiRacing www.fuji-racing.com 2010 13B Rotary Miata Semi-PP 2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a) 2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a) 1990 FC3S Street Car |
#17 |
Yes, finally someone making Miata rotary Kits at a reasonable price. Are you focusing specifics(drop in and turn key) or just a base essentials (subframe,drive shaft,wiring, etc).
Very interested in a Base essentials style kit. |
#18 |
First just the base essentials, like mounting the the engine and utilizing whatever we can with the least amount of custom parts then go from there. Keeping the price reasonable is our main goal.
#19 |
Tommorrow I will be pulling the motor out of the FC and I will have Ricardo over (Kilo Racing Machinist) and Raul, and we will test fit the spare engine into the Miata to see the best way for mounts.
#20 |
Got a pretty good idea now. We will be making a custon bracket so that you can bolt the engine in. Looks like no welding and will be bolted in. Subframe may have to be notched slightly but no firewall cutting.
Price range $500-$700
#21 |
On Saturday we took the Miata tranny out, took all of 15 minutes. Gotta love RWD. This way we can test fit and make the custom bracket with the engine/tranny. We need to have the car ready for the Superlap Battle in November.
#22 |
Rep Power: 21 ![]() |
just curious, how you ever used megasquirt? Might just be in my tuning in general, but im having trouble figuring out what the car wants with these ITBs.
#23 | |
Good news I just got. The REDLINE TIME ATTACK has a meeting with Sebring Raceway and if they can secure a event there we need to have the car ready.
#24 |
We will be including a New Oil Pan in our swap kit.
#25 |
Pulled the FC Motor apart and we will be able to use the 9.7:1 Rotors and we will be using the 4 port 12A or 4 port 13B side & center plates.. It's been done before and we have the machining capability. Looks like we will be using the Kaaz LSD, since that is the best one for the Miata in our opinion.
#26 |
Whose EFI (Blue Trumpets) Throttle Bodies are those?
#27 |
^^damn that is nice!
#28 |
Rep Power: 10 ![]() |
Look like Tweakit's to me.
#29 |
Thanks! That's what we are looking at now since we want to use twin fuel rails with 4 injectors.
#30 |
those are from tweakit..in AUS....very affordable too
I just comleted my miata turbo rotary swap...went weber blowthorugh...did some initial dyno runs on 5 psi and made 250 whp....not too bad for a To4e on low boost.. just waiting for spring to get here so i run her out a bit.... will post some pics when i get some |
Bookmarks |
Tags |
13b rotary miata |
