Old 01-24-2010, 08:26 PM   #1
The stock AAS is not crap. It was good for what it was, remember this is 20+ year old technology.
FWIW my AAS still works on a 140K chassis. The motors turn the valves, and the suspension firms up. Hit the button, and it feels a little smoother over bumps.
Sorry Max, but you seem to have a hatred for what it essentially an AGX or Tokico that only has 2 positions. It isn't that crappy. The AAS on my 626 worked great too, and it was 3 position!!
Regardless, you should replace the struts and springs at the same time. No reason to take it apart twice.
All you have to do is remove the assemblies as a whole. Buy new struts mounts, and put together the new struts/springs, then bolt them back into the chassis.
Then, go get an alignment.
Old 01-24-2010, 08:31 PM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
^^^ Yep, leaning more towards removing it now as I'm going to have to replace the struts anyway, and the stock replacements are all $200+ new. I could go with the Tokico Illumina's and still pay less and probably have a better suspension feel.
I figured the removal/intall would be the same as with any car, but what all is involved with removing the AAS system as a whole? IE, the ECU, wiring, switches, etc?
Old 01-24-2010, 09:28 PM   #3
It's crap.
Old 01-24-2010, 09:35 PM   #4
Originally Posted by Max777 View Post
It's crap.
Alright, but all things being equal, I can hang with any combination of suspension on the Dragon.
Old 01-25-2010, 04:42 PM   #5
That just means you might be a decent driver and can use the car better than a lesser driver with better suspension. Tires also play a big part in it, some Toyos will make any relic handle like it's new again, while a guy with stiff suspension and worn out all seasons wont be as fast.
