Old 01-11-2010, 02:04 PM   #1
dudemaaan
dudemaaan's Avatar
check the compression just to see what it is, if used housings and such were used then compression won't be as high and it can take longer for everything to seal up. Hot start problems is usually a sign of weak compression, too much fuel in these situations can also make it harder to start.
