Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Re-Speed
Re-Speed www.re-speed.com (GA) Custom rotary parts, specializing in 85-older
Old 01-05-2010, 09:47 PM   #1
josh18_2k
problem with sway bars is they are a non linear spring (rate depends on roll) so its harder for a damper to properly control the spring/sway combo. ideal damping at full lean will be underdamped at anything less
soft springs mean more pitching/squatting on brakes/gas, which are both bad for grip and handling
my local suspension guru chris billings swears by choosing springs for roll/pitch/dive/etc, and using ONLY a front bar to balance the car mid-corner
Old 01-06-2010, 01:05 PM   #2
Kentetsu
Kentetsu's Avatar
You have to remember what the other end of the swaybar is connected to (yet another spring/damper combination).
"soft springs mean more pitching/squatting on brakes/gas, which are both bad for grip and handling". Absolutely not true, if combined with good swaybars.
Anyway, I am not going to start an argument in this thread. As I have said, there are two schools of thought on this matter. I am of one, you are obviously of another.
But while you are here, why don't you take a look at this video. Maybe then you will consider that there might just be a slim possibility that maybe, potentially, I really do have a point.
http://www.youtube.com/watch?v=rWpEYAKo0fU
Old 01-06-2010, 02:32 PM   #3
Rogue_Wulff
Non Member
The swaybars have no effect at all under accel/decell conditions, regardless of whether they are 1/8" or 5" dia. Spring rate and dampers are the only things that have any effect on dive/squat, aside from geometery.... Springs determine how far it goes, and dampers determine how fast it gets there.
Otherwise, you do have a valid point. Softer springs can be benefitial on rougher courses. Can go fast with the tires dribbling......
A wise man once said to me "Stiffer springs and swaybars will usually make a car faster, but harder to drive". Of course, he was refering to handling, not straight line speed. It was during an autox/road racing suspension seminar......
He also said to use springs to adjust the car, and swaybars to fine tune the springs.
