Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > NRS Rotorsports
NRS Rotorsports www.nrsrotorsports.com (Canada) Ceramic apex & corner seals for rotary engine applications
Old 12-28-2009, 08:08 PM   #1
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
Do you know what the failure rate is for milling them deeper for use in earlier 13B engines? I'm assuming that's the milling that you did have performed, correct?
I did have it performed by Speedsource. I do not know that the failure rating is - but I know it's pretty low.
Originally Posted by thewird View Post
Is what your referring to a machining error? As it needs to be a very accurate/precise machining process? So it being the machinists fault and not the rotor itself?
When machining an FD rotor to 3mm, there have been many cases where machinists don't get it spot on and trash the rotors. But this has to do with the machinist you go to. Once you find the right machinist, trashing rotors is no longer a problem.
Just trying to figure out why. Thanks.
thewird
Kevin can better answer that question - obviously 99.999% of the time is machining or material defects.... nothing technically should prevent you from running a 3mm seal in a RX8 - I just was unwilling to take the risk since 8 rotors are pretty expensive.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 12-28-2009, 09:44 PM   #2
thewird
thewird's Avatar
thewird is on a distinguished road
Thanks, that's what I wanted to know. My builder knows a good machinist that always gets it bang on so I don't have to worry about the RX-8. Was worried there was something that specifically was different on the RX-8 rotor that prevented 3mm from happening.
thewird
thewird is offline   Reply With Quote
Old 02-21-2010, 12:20 PM   #3
glassman
Premium Vendor
glassman's Avatar
glassman is on a distinguished road
RX8 rotor & cut away for 3mm full height seals
A customer of mine in Russia is looking at running 3mm full height ceramic seals in RX8 rotors. Below is a pic of an RX8 rotor cut away showing the meat available in the slot as well as a stock RX8 rotor for comparison. Please note the cut away slot is not standard RX8 depth because they were using apex seals that are in between OEM height (FD) and RX8 height at 3mm width. Their slot in the cut away is 8.80mm or 0.3464", the total meat available is 12.20mm or 0.4803". This leaves approx 0.1339" to the bottom of the casting. The full height slot should be 0.385" deep leaving 0.0953" of meat remaining, almost 100 thou. From the picture the slot would be deepened another 0.0386", less than 1mm.
Hopefully this info will help others to make a solid decision when considering 3mm full height seals in RX8 rotors.
Thanks Dmitry for this excellent info!
Mild to wild, street to strip, when you want to go fast and you want your engine to last, NRS Ceramics is the only way to go.
NRS Rotorsports
nrsrotorsports@shaw.ca
glassman is offline   Reply With Quote
