Viable Fossil
Look for a rotary specialty shop close to you. Depending on what's wrong, it's usually less expensive to rebuild than to replace.
RHD cars originated in places where I suspect "routine maintenance" had a much different meaning. It's also my sense that their value is falling quicker than LHD models....so check the rest of the car carefully.
Jim VR R1 FD |
#2 | |
#3 | |
Viable Fossil
For me and what I wanted a couple of years ago it was easier and less expensive to rebuild for a coolant seal. He also mentioned modifications and port work could be done at the same time. Had I had a hard seal failure a reman might have been the way to go though.
Jim VR R1 FD Last edited by Signal 2; 11-29-2009 at 02:35 PM. |
#4 | |
Personally I found a rebuilt used motor with lower miles on it and bought that, ended up being cheaper than a base rebuild and has turned out great. BUT again it's kind of a crap shoot and you really want to make sure you're buying from a reputable seller so you don't end up with a bad motor. |
