#11 |
frustrated!
Rep Power: 17 ![]() |
Thanks man! I was happy once it was finished. Just got the sheet metal from good old ACE in .032'' and used some avaition shears.
**one note: to secure the bottom of the long shield that is secured by the UIM nut, I rounded the bottom edge(look closley in the first pic) and drilled a hole where the front rotor housing exhaust manifold stud is. Then you can get a ratcheting 14mm wrench down there to snug another 14mm nut tight over the shield to keep it flopping around. Total cost was like 40.00 with DIY heat shielding matting included. I am SURE you will conjure up something sweet. ![]() BTW Does anyone know which way the rear swaybar endlinks go: Larger bushing eyelet up or down? My FC had one side oppisite the other WTF??
Same pig, new soul
