Old 11-20-2009, 09:56 AM   #1
Thats high on a 1000cc inj for only 15lbs or less... crazy! I'm still plotting that side of my setup out. I'm sure I'll end up with 1300 or 1600 secondaries. Been contemplating running four secondaries though instead and two primaries... we'll see...
I'll discuss the "fun" ports when I get to that stage... its the big key difference between your engine build and mine and w/ Nismo's (Kevin?) as well.... we will all have uniquely different setups which will be cool to see the power curves. Peak power will probably be within 50hp or so of each other.
My trans was rebuilt about 12K miles ago, but nothing special. It shifts fine, but that was with a street ported S5 block and ported stock S5 turbo around 8psi... nothing crazy. I'd rather get the trans addressed while its out of the car then put it in only to have to take it back out. It is a jspec version as well, so no overdrive for me Maybe someday I'll venture down the 6spd path...
For the LS2 coils it wouldnt be a simple swap of the pack unfortunately since I have RB race wires which have a different boot connector than whats needed for the LS2. So I'd have to make a pull, swap the pack, pull the wheel and swap the wires - not hard, just an extra step involved. From the rx8 community the general belief is not much on power when your NA, but more about the clean burn and fuel efficiency which is really all I'm looking for and the reliability of them is an added bonus (and cost.. I only paid $20/each).
Old 11-20-2009, 11:01 PM   #2
Meh, not really, look at the power. I originally planned for 350-375 as a starting point and then upgrading if need be. I guess the need be is here. 90% is a little too high and I want to try a new injector. One with a better spray pattern, something a little more predictable and hopefully get my idle above .83-85L ... bleh
Uh huh.... uh huh.... I see
I'm going to corner the market for the 6-spd FC conversion if this all works out. It won't be all that cheap but it will bolt right in. Just need to address the speedo crap. Not an issue for me..... suckers
Honestly, I'd leave the tranny alone until you start to have problems with it..... JUST DON"T USE ROYAL PURPLE! That stuff blows. The Type R trans is good for some serious HP and torque before it becomes a weak point.
I see, I see. So even if you had a set of wires premade, you'd still have to pull a wheel to swap wires? That kinda.... sucks. Where in the hell did you find them for $20 each. more importantly, where are the 4 that you didn't get. 'Cuz I want them..... now.
