| 3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
Rotolicious
My entire 500hp REW setup
I've decided to move onto bigger and better things. As such, I'm selling my entire REW setup, which is as follows...
Here's what the setup is... Half-bridge 13B-REW by BDC S4 TII rotors GZ LIM CJM Fuel rails w/ -10 Inlet 850/1650 Injectors FJO Injector driver Blitz FMIC Synapse Synchronic BOV HKS Twinpower Aeromotive FPR Coil relocation bracket T04Z kit by Turblown Long runner manifold w/ closed WG dump 4" DP/non-rez MP Tial 44mm WG Power FC/black box datalogit Intake manifolds and IC piping ceramic coated by LO-KO in Oak Lawn, IL. Exhaust manifold and DP coated and wrapped GZ Oil pan w/level sensor Steel OEM motor mounts. I can give the pucks as well. Everything else internal is OEM or otherwise stock. Turbo may need a new CHRA since the last track day. Made 439 WHP @ 20psi on 100 oct (and I had a small, unknown at the time boost leak) I'm guessing the setup may have about 10k miles on it. Maybe less. The housings were new for the build. The irons were from my original motor, which have maybe about 50k miles on them. I didn't exactly write the mileage when I got the new setup. Pics, comp #s and dynosheet fourthcoming by this weekend. $8000 semi firm. I'm not looking to part out per se. The idea here is a plug and play setup. I think that's everything listed above. It's basically everything from in front of the flywheel to the intercooler. No, the clutch and FW are not part of this sale. Neither are the fuel lines and pump setup. Please email me at admin@chicagorotary.com for more info and I can email specific pics from there. Also, I'm not exactly looking to really ship this out. I will if I have to, but realize that it will lengthen the time to get it out the door. Thanks! Christian
Rc³ |
Always Under Construction
Let me know if you decide to part out.
BLACKADDE™ | ADGT RX7 | |
Hey I am itresting in afew parts as well if u deceide to part out.
Coil relocation bracket T04Z kit by Turblown GZ Oil pan w/level sensor GZ LIM Khris |
In Too Deep
Rep Power: 17 ![]() |
Interested in the PFC, if you decide to part out.
1990 TII, fresh rebuild Atkins rebuild kit, RA apex seals Med. Streetport, TB mod, rebuilt turbo, ported wastegate, GodSpeed FMIC RacingBeat Turbo-back straight exhaust, Bonez test pipe, emissions/nest removed hks intake, Walbro, Profec B spec-2 |
I thinking he is missing in action since he has nor relpy any of us, oh well.
Khris |
