Old 02-20-2009, 09:18 PM   #5
proz07
Needing a new tow rig.
proz07's Avatar
i do hve a question though with the clutch pedal mount? Take a look and if you could check yours let me know if this is right? im going to look in the FSM see if i can find anything but if anyone can check that would be great.
Well iv bee alot busier than i thought i was gonna be so im still working on sound deadening but before i did that i decided to change the clutch out from a solid 6-puck to a street modified ACT disk. i only changed the disk as the clutch was new and only has 2k miles on it practically new.
I refilled the trans with REDLINE SHOCKPROOF HEAVY weight as the trans was grinding in everything but 4th assuming bearing noise but it was loud with royal purple. So hopefully this will quite it down with the rest of my "comfort" mods. THis stuff is one step away from grease it is THICK!!!
At this point i have around 20+ hrs in sound deadening time and much more to go. I'v been looking around and it seems im doing quite a bit more than most have done. So we will see how it turns out. As you can see in the red circle i also did the firewall as i already pulled he dash, I figured might as well do as much as i can so i dont have to do it later. Basicly do it right the first time and it comes out cheaper.
