Old 11-26-2008, 02:16 PM   #28
dregg100
Originally Posted by RotaryProphet View Post
Actually, if you look at his schematic (I just did, to figure out what this was all about), he has the sensor that fires the leading plugs split to two coils, so as to fire both the leading at the same time, then the trailing fires as per stock through the distributor. I ran my ~400hp turbo bridgeport 12a this way (although through a pair of MSD boxes) for months. Your hung up on the fact that there's two leading coils and one trailing, which makes you think the leading is firing at different times, but what you're ignoring is that the trailing is still firing through the distributor, and both leading coils are wired to the same signal, and so they both fire at the same time. It's a spark power issue, not a spark timing issue, all the coils still fire based on the distributor's sensor.
i forgot about the dizzy!!
'93 SSM Touring-S475...
'87 Tii-LS1/T56
