Old 10-16-2008, 11:22 PM   #1
Einstein
Einstein's Avatar
Einstein is on a distinguished road
What can I pass emissions with?
Greetings,
I have my motor apart on a bench at work. The question is: what can I do and still pass emissions? I was hoping to do emissions removal per RR and possibly DIY porting. I live in Cherokee county in Georgia. Here is what we have to pass.
All 1995 and older model year vehicles will receive a four-part inspection:
* A visual inspection of the catalytic converter to check for tampering or removal.
* ASM2 or Accelerated Simulation Mode Test - A dual-mode test including a 25/25 test = 25 percent load at 25 MPH and a 50/15 test = 50 percent load at 15 MPH.
* A tailpipe exhaust emission test.
* A fuel cap inspection to check for adequate seal.
The first and last are the easy ones. It's those darn middle ones that will probably get me.
Thanks in advance.
Past: 89 RX-7 Turbo II
Past: 88 10th Anniv RX-7 Turbo II
Einstein is offline   Reply With Quote
Old 10-17-2008, 07:24 AM   #2
Run two cats and use either the stock air pump, or an electric one from a Corvette, or an Envoy/Trailblazer.
Good luck!
Old 10-17-2008, 09:56 AM   #3
stylEmon
stylEmon's Avatar
if it's a turbo, disconnect the wastegate rod. Its real easy, just a little clip. I did it with the turbo installed. This will keep them off the boost.
I ran the air pump right to the cat.
http://87rx7.blogspot.com/2007/06/ho...t-my-wire.html
Old 10-17-2008, 10:39 AM   #4
Whoops!! I meant to say run the air pump directly to the cats.
Old 10-17-2008, 12:44 PM   #5
im guessing the middle test is to keep people from running too retarded timing??
i've passed with:
'87 n/a
- no emissions, one aftermarket cat fed with air from an air pump, retarded timing, and 5 bottles of ISOHEET on 1/4 tank, passed with 212 out of possible 220 HC ppm, and the CO were close too
'89 n/a
- stock motor, emissions, no cat (had a gutted cat on there when I bought it. I didn't even know it was gutted. Maybe thats why it was so loud), passed with 8 PPM and only a few CO.
7s are weird...
Old 10-17-2008, 05:17 PM   #6
Einstein
Einstein's Avatar
Anyone know if I can take any of the solenoids and stuff off? What I am trying to do is clean up the engine bay. I plan on running a cat, but don't want the others.
Also anyone able to pass with any porting?
Old 10-18-2008, 12:39 PM   #7
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
Atkins Dan is on a distinguished road
you can still pass with engine porting just as long as the air pump and cat are working correctly you will be fine.
Dan
82 SuperCharged rx-7 {my toy not the daily driver anymore now under restoration}
88 B2200 rotary powered with a 7inch Camden SuperCharger !RIP! Jan/4/2007
2001 626 5-speed 80k on the clock all stock {Truck replacement}
2005 MAZDA6 V6 WAGON now that is a pimping ride all stock for the moment.. Paid off
WWW.AtkinsRotary.com
Atkins Dan is offline   Reply With Quote
Old 10-18-2008, 03:43 PM   #8
Einstein
Einstein's Avatar
Sounds good, thanks guys. Now I just need to put the motor back together
Old 10-19-2008, 05:22 AM   #9
It depends what kinda numbers you're trying to get under...
Old 10-21-2008, 07:55 PM   #10
Einstein
Einstein's Avatar
Good point. I'll call a station and find out. Thanks.
Old 10-24-2008, 11:14 PM   #11
savannafc4me
savannafc4me is on a distinguished road
I was wondering can I pass with Headers and a mild Street port??????? I live in California.
savannafc4me is offline   Reply With Quote
Old 10-24-2008, 11:16 PM   #12
savannafc4me
I was wondering can I pass with headers and a street port????
Old 10-24-2008, 11:51 PM   #13
As far as I know headers would be illegal in cali because they eliminate the 2 pre-cats, and knowing how strict the emissions are over there, I would say no.
but you could always bolt up a stock mani and gutted pre-cats and pass fine.
I have a stock mani, as well as the 2 small pre-cats for sale if you need them btw.
Old 10-27-2008, 10:14 PM   #14
mfisher12
mfisher12's Avatar
mfisher12 is on a distinguished road
i have an 86 N/A with no emissions components and a racing beat true dual exhaust and pine-apple racing 5th and 6th port sleaves and i ran a practice emissions test: HC 668ppm NOx were very low due to the richness. surprisingly CO and CO2 were close but still failed.
cats and air pumps are the key
mfisher12 is offline   Reply With Quote
Old 10-27-2008, 10:20 PM   #15
Einstein
Einstein's Avatar
Wow - go HC's!! I know that I have to get under 150 HC's. I don't remember the other stuff. Still haven't had time to get that info.
