Show your rotary car build up. Show off your Rotary Car build! |
Rep Power: 15 ![]() |
OK Guys Exciting times ahead. James and myself will be building our first 26B this summer. So I thought I would make a start on a build thread to keep everyone up to date with our progress. I've copied over the thread from fduk.org and I will get you guys up to speed and then I can keep you updated.
www.TGSTUNING.co.uk Everyone will remember James 20B which he mainly built himself in his garage at home. This time I will be taking care off almost all the fabrication Tuning in house here at TopGear Stockport. ![]() ![]() The plan is to offer a full conversion drop in package complete with all auxiliaries for the FD3S we will be using the M6000 Adaptronic ECU along with Jenvey throttle bodies. We will soon be publishing the Facebook page dedicated just for this build https://www.facebook.com/TGS-Tuning-...1788402513399/ Out with the old James is preparing the car ready for the work at TGS ![]() ![]() And I all know you wanna see the shaft ![]() out with the 13b ![]() in with the Mock up motor ![]() More updates coming soon Regards Craig
![]() 95 FD3S Type RB Project BorgBoost 550BHP 93 FD3S Project 26B 1200+bhp rolling road dyno +44161 4948343 www.tgstuning.co.uk https://instagram.com/craigtgs/ Last edited by Topgear; 07-11-2017 at 12:50 PM. |
Post from James
Abit more on progress. Still awaiting for the parts to arrive at top gear Stockport. I've cracked on with engine bay work, and will start some body work soon. So new brake lines are swaged in, running a pedal box for the brakes. Wiring is all chopped back now and removed what is not needed. New forward engine mount welded on and polybushed. Engine bay is rubbed down and repainted, rebuilt the engine bay with the mock engine slaved in ready for Craig's fabrication skills. Anyway here's a few pics. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Regards James
![]() 95 FD3S Type RB Project BorgBoost 550BHP 93 FD3S Project 26B 1200+bhp rolling road dyno +44161 4948343 www.tgstuning.co.uk https://instagram.com/craigtgs/ |
So another quick update before the car leaves my house in the morning to Craig's workshop top gear Stockport for all its fab work. Car has be rubbed back to primer, and repainted in red, I didn't take too many photos but here are a few, I'm sure the next updates will come from Craig now over the next few weeks.
Ok I rolled out the red carpet for jame today and made a start on the project
Mocking up the sump pan in cad ![]() Her new home for a few months the 2 post project ramp ![]() ![]() ![]() I'm sure I will have plenty of updates for you fdukers over next few months More to follow Regards Craig
Hi guys been very busy designing the headers for the motor which isn't a simple task. Quite a lot of length is needed for the PP so much so that if the headers were straight the collector would be where your backbox is
![]() ![]() ![]() as you can see for me to be able to fit the package and also be able to run some sort of silencer, we have come forward with the runners to gain as much length as possible without interfering with the pp intakes, I also have the length dialled in bang on the money all four hit the rear of the subframe at the same length. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() off the car ready for welding ![]() ![]() thats it for the first stage of the primary runners. next will be the tunnel runners to the merge collector and if there is room some sort of centre resonator. Regards Craig
We also got the oil pan base plate cut. first we cut a test 1mm flange in house on the cnc plasma and to my amazement perfect fitment first time only been learning cad for the past few months but I'm really enjoying it.
![]() ![]() Then off to the water cutters for some jetting ![]() ![]() Perfect fitment ![]() ![]() more to follow on the oil pan Regards Craig
next up I needed to turn some solid mount to replace the mock up mounts
new front mount radiator mounts loving the way these turned out
#9 |
The money Shot
#10 |
ok updates are going to be slow this week as I don't have a phone as its in for repair. managed to steal andys phone to take these today.
so more progress on the oilpan and pick up. ![]() ![]() ![]() ![]() Regards Craig
#11 |
Professional Stick Poker
That's way too cool. You guys are going full beast mode this time.
#12 |
cheers dude yeah we have moved on quite a lot since my first build
#13 |
Awesome build!
#14 |
Rep Power: 12 ![]() |
Good stuff, keep updates coming.
#15 |
I'm quite far along with the oil pan now no photos this week as my phone is in for repair at the shop. soon as its back I will update with some photos.
as for weight over the front axle only one housing, a centre plate and the front cover over hang the axle. no more than a v8 no turbos also means less weight up front. Regards Craig
Bookmarks |
Tags |
26b, 4 rotor, rotary, tgs, tgstuning |
Thread Tools | |
Display Modes | |
