Old 07-29-2016, 08:12 AM   #18
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
The car won't be going anywhere for a while as I've got the steering column pulled apart to replace the upper bushing, which had crumbled to pieces causing play.
Mine was the same way when I got it. The bushing was little bits and pieces, that which wasn't powder. I solved it by going down to a bearing specialty place and was able to source a metal bearing that fit the steering shaft. It was slightly large on external diameter so I had to do a little filing on the plastic for the turn signal piece and used a socket to expand the metal tube slightly so the bearing would slip in. It is solid and turns easily now. No more slopping around when you try to turn the wheel.
