Old 06-23-2015, 01:43 AM   #11
chibikougan
chibikougan's Avatar
It is close (just like everything else in this 5 lb. sack ), but yes, it should. The hood bulges upward toward the middle with no inner structure, which is the only reason that my manifold clears. I'll see for absolute sure next time I trial fit the hood. It wouldn't be the first time I had to go back and re-think something.
edit: damn it Ransom, you got me worried and I had to go out and reinstall the hood to check it. There was a clearance issue. Not with the hood per se, but with the mounting tab for the hood prop. Chopped off the tab and it closes just fine.
Wheww! Good eye.
I do have another clearance issue with the coolant inlet pipe. It touches on the inner curve of the bend. I was planning to cut and swivel that to a more forward angle anyway. The outward angle is a bit extreme for this car and now that I know it touches the intake piping I'll definitely need to modify it to face further toward the front of the car.
Good deal..
My OCD kicks in I would be fucking with the hood on and off constantly. Like checking the door lock even though I fucking know its locked I just checked it 8 times but I am still going to check it however many more times...
chibikougan is offline
