#1 | |
Get off my lawn!!!
Rep Power: 15 ![]() |
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
Don Mega
From my memory they are the same dimension so yes, but will validate that this morning my time and post back.
#3 | |
Rep Power: 10 ![]() |
Just run the 7420's dude.... the reason I generally rec AGAINST colder plugs is because the ign system isn't up to snuff to properly fire the plugs. Change to colder shitty 6750 I think???? and need to "retune" the car because the AFR's are all over the place, then as you're pulling fuel out you see the EGT's go up... fuck that noise...... These coils I don't see as having a problem.
Rep Power: 20 ![]() |
But I don't wanna! lol I had the mounting bracket welded to the frame with the bolts sticking out, and I don't want to move the pump again and just leave all that exposed. If I could remove the bracket and make it look good like the stock frame again, I'd seriously think about it.
