| Introduce yourself!! Tell me something about you and your history with rotary.. |
				Rep Power: 0 ![]()  |
				Rx7 FC Adjustable Rear Toe Links
			Rx7 FC Rear Toe Links are now for sale! $175 + Shipping!
	The Hex is adjustable with a 1" wrench, and the locking nuts are a 1 1/8th" wrench. They are a direct fit and allow for standalone rear toe adjustment. ![]() ![]() ![]() Pm me for info!  |
		#2 | |
				Rep Power: 17 ![]()  |
			What is done to the tapered holes in the subframe and control arms?
			Do they travel freely up and down? Can you get a picture with the center propped up and let the control arms sag as far as they can?
			Oh man, I put this in all kinds of the wrong section.
	Anyways the taper that you see on the stock links is simply a location finder because the stock toe link studs are significantly smaller than the actual hole. Only the first 3/8th" of the hole is tapered, the rest is a regular non tapered hole. The bolts used in these adjustable links fits and fills the regular non tapered part of the hole allowing for a tight fit and no movement. These has been used on several cars including an 8.8 swapped LS powered FC, which is the sub-frame in the picture. I will see if I can get a picture like that but my set is back in a driving car.  |
		#4 | |
			The holes are tapered I had them machined for inserts. Yeah that's all I needed to hear thanks anyway.
