Old 12-24-2014, 05:12 PM   #11
mazpower
Rawr Bearclaw
mazpower's Avatar
and this is coming from a man that needs all the braking he can get.
Brakes are for pussies. Nevar lift breh!
What kind of noise do they make? Is it a squealing or like a chatter or something? All the time or during braking or what? Is it just from the friction between the pad and the rotor?
High pitched squeal on light braking. Nothing on heavy braking. Depends on brake temp too. I ran XP8s on my old S2K (my wife's now) and it would squeal horribly if you crept up to a stop. If you stopped quick with good pedal pressure, it wouldn't make a sound.
Yeah I've seen you post about them. So the XP10/XP8 combo has enough cold bite for the street? That's one thing I'm worried about. I'm planning on ducting the front brakes when I install all this so I'm wondering if I can use the AX6s and be OK. I'll keep the wheels clean, no worries there. My main issues are noise and cold bite.
I've never had any cold bite issues. The very first time you brake on a cold day might feel a bit "vague" but no issues with stopping. After that, they feel fine. I've never had a problem with my XP10s cooling off too much and losing any feel. In comparison, the Wilwood E-Prod pads I used to run on my Miata were horrible that way...they had to stay hot. Not the case with the Carbotechs. Also something to consider is my "cold" temps never really got below 30 degrees F, if you live somewhere colder than that, not sure how that would affect things.
Noise really is the big one but with the stock calipers on the FD and NSX I don't really hear much. NSX will make little squeaks every now and then and the FD is silent. S2K was like a damn school bus and same for the Miata. Never used any brake quieting compound...I tried it once on the S2K and ended up just melting the brake quiet lol.
It doesn't seem like anyone really knows about Winmax yet. Oh well.
Thanks guys!
I've never heard of those pads. If you end up going that direction let us know what you think of them...very curious!
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
