Old 02-03-2014, 08:47 PM   #11
JhnRX7
JhnRX7's Avatar
So my FD is down for the winter and its time for some long overdue motor work. The last time the current motor was out of the car was in 2004. I have not put a ton of miles on the motor (maybe 35k), but they have been hard miles. I had been having smoking issues over the past year so I finally decided to pull it and tear it down.
Seeing as I built this motor when I was 17, there were quite a few things I would have done different had I known better. It appears that I had ported slightly into the oil control ring causing the front oil control rings to wear well past spec. I believe that, combined with using the original (now 120k mile) metal control rings ultimately led to the smoking.
There were other issues I found while I was in there, chattering from the 3mm seals, a dented rotor, and poor side seal clearance on the rear rotor just to name a few. The rusty coolant passages were from years ago when I lived in FL I made the mistake of running the system with little to no coolant.
See the blow by here… this explains why my catch can was filling with fuel!
I have cleaned everything and stacked the parts away on a shelf until I decide what to do. I want to start over with a 2mm motor, and polished stock ports. For now, I am focusing on other projects.
ducting, ducts, fd3s, jhnrx7, track
