IT'S ALIVE!
So I got the 1-2 and 5-reverse backwards in my first response and yeah, the control end bushing is only in the series 5 n/a transmission (thanks Rotary Revolution) so here's try #3. Have you tried taking the control end assembly apart and putting it back together again? There is a specific order some parts need to be installed. Have you tried with the shifter completely bolted back in? You picture above shows the shift lever without the lower boot and mounting flange.
#2 | |
In the last picture I posted am I missing something? I was thinking there was supposed to be something else there... this was completely apart when i got it and the factory service manual doesnt show a good parts break out for the shifter. |
#3 | ||
IT'S ALIVE!
![]() Again, I don't know how different the TII transmissions are from the n/a ones but in my case the flat spot on this feature needs to be facing the rear of the the car. Here is where the order of installation is important. After the control rod end and roll pin are installed next is the large spring and the plunger (these are what provide the spring force for 5/reverse). After that is the small steel ball, small spring, and bolt. Any important step is to rotate the control rod end as if you were shifting into 5/reverse before installing the steel ball and spring. The steel ball has to engage the flat spot on the "plunger." Since you said you can get into every gear I don't think this is an issue and either way, this shouldn't affect the 1/2 return. Quote:
![]() Looks the same, right? |
