| RX-8 (2004 - Present) All things to do with RX-8 |
rotary owner/driver.
Coolant & Oil temperatures
I am getting ready to pull off my front bumper
#2 | |
Your engine is designed to work most efficiently at a certain temperature RANGE. If you're trying to run it too cold, you're just wasting fuel and possibly causing premature engine wear - hell, why would you care cause you advocate shutting the engine off after revving it up to 3k+ RPMS! Unless you're having overheating issues - are you? - there's no reason to be changing anything, including the radiator. A larger radiator does nothing if your previous radiator worked fine. If your previous radiator worked fine, then upgrading to a larger radiator just causes the thermostat to possibly work harder and possibly fail prematurely. -Ted |
BOILED PEANUTS!!!
Why are you wanting to install a secondary radiator? Are you having cooling issues now? If so the issues causing that needs to be remedied before any modifications are done. On to the answers to your questions:
Oil temps do not turn on the fans, coolant temps do, and they turn on at around 210 F. Rx8performance.com sells a relay kit that turns them on at 185 F, I have that on my car. For the oil temp sender I found it best to get a modified banjo bolt that you can screw the sender into and us it to replace the banjo bolt either on the front cover or drivers side oil cooler (put it on the side pre-cooler not after) You can get an oil filter sandwich adapter but I found that the oil filter location made the thing a bitch to deal with.. I ended up throwing mine across the driveway in frustration and ordered the before mentioned banjo bolts. Again, Scott at Rx8performance.com made those for me. All in all the cooling system on the rx8 is very good if functioning properly, unless you live in extreme heat or track the car it should be fine. Do you have a undertray that is intact? it is an essential part of the cooling system
![]() www.rotarycarclub.com "The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot." |
#4 | |
?. You sound almost angry?.
#5 | |
#6 | |
BOILED PEANUTS!!!
#7 | |||||||||
Let me just preface this...
I've been dealing with newbs like you for years now. I've been dealing with newbs like you online for over 20 years now. I can smell them from a mile away. You think you know what you are doing. In actually you have a lot to learn. You know just enough to be dangerous. You also have a chip on your shoulder that if you get criticized, you get all defensive and get all butt hurt. Get over it. You asked a public question on a public forum - be prepared for responses that you do not agree with. Quote:
If you're buying and swapping stuff just for the sake of doing so, then none of this applies to you and just ignore anything I say, period. When I build my cars, I change and mod things that NEED to be modded - nothing more; nothing less. My philosophy is: function over form. Quote:
Since we're comparing resumes... Quote:
You made your point. I came to the conclusion that you're not going to listen to anything I had to add, thus, I ended my involvement in that thread. Quote:
Ask anyone who has known me for a few years - my road is littered with ignorant people like you...thousands... Angry? You're giving yourself too much credit. I'm sitting here smilin' and laughin' at how much you don't know... Try again. Quote:
-Ted |
I'm really confused. Are you installing a new coolant radiator in place of the OEM one? Or - are you installing a new oil cooler in the center inlet thus removing the driver's side oil cooler?
Is your car auto or manual? I understand that you "race" down mountain roads and that your car gets hot, but by your own admission you just bought digital gauges to view the temperatures of both oil and coolant. This means currently you're relying on the factory gauges which is a terribly bad idea. If any of your temp gauges are reading more than "normal" or slightly less than half way in an RX8, you've probably already cooked something and no amount of additional/larger coolers is going to solve that problem. |
#9 |
BOILED PEANUTS!!!
The coils are in a crap place, but I don't know that any amount of ducting will cool them in the stock location. Want to fix the issue? move them.
#10 | |
#11 |
Actually you are correct.
#12 | |
Wow! me too. If you don't have an 8 its probably best you do not comment on the 8. Make sense ted. Here is a nice 1st generation 7 Last edited by rotar bones; 08-04-2013 at 04:14 PM. |
#13 |
You don't need to move your coils. The upgraded BHR coils (LS2) have heat sinks in them and they don't sit near close enough to the exhaust to cause any REAL problems. I've run a similar setup as what BHR offers for years now on many track days with no issues other than plug wire failure (unrelated).
Now - unless you WANT to move them because you're bored and looking for something to do, by all means. Although almost anywhere else you move them to will involve lengthening your harness and plug wires which if not done properly will probably cause more harm than good. If you're really trying to be different - why don't you tackle doing a 6spd swap into your automatic? That'll be your biggest bang for the buck (swap in the 6 port engine while you're at it).... |
#14 | |
Not Last edited by rotar bones; 08-03-2013 at 09:22 AM. |
#15 |
The 06 and newer RX8s have 6spd autos.. you could do that swap.
Worn grommets? Please elaborate. |
