RX-8 (2004 - Present) All things to do with RX-8 |
#2 | |
Your engine is designed to work most efficiently at a certain temperature RANGE. If you're trying to run it too cold, you're just wasting fuel and possibly causing premature engine wear - hell, why would you care cause you advocate shutting the engine off after revving it up to 3k+ RPMS! Unless you're having overheating issues - are you? - there's no reason to be changing anything, including the radiator. A larger radiator does nothing if your previous radiator worked fine. If your previous radiator worked fine, then upgrading to a larger radiator just causes the thermostat to possibly work harder and possibly fail prematurely. -Ted |
Bookmarks |
Thread Tools | |
Display Modes | |
