#10 | ||
1) heat cycling will cause the epoxy to loosen or even break up, 2) Additional exposure to coolant and / or combustion gases can only hurt. I've used housing like that, and Hylomar takes care of any worries of sealing. Quote:
If fact, it'll make it harder to do the end play procedure with more weight on the e-shaft. The only thing that matters is that the "front stack" is complete and torqued down to spec. This includes everything under the front oil cover + front pulley boss + front eccentric shaft bolt torqued to spec. -Ted |
