| DGRR Archive Threads from Previous Deals Gap Rotary Rally Events. |
		#31 |
				Rep Power: 18 ![]()  |
			To do list on 94 (friend's car)
			-remove old engine- tranny, drop in new engine - tranny - done long time ago -convert old single setup to simplified seq. setup - done -put in new stock turbos - done -blew stock twins on dyno ( bad turbo from ebay!) cough cough -install new GT35R turbo / convert to single, etc etc - done -install shitty ebay intercooler - done -dyno tune on shitty chinese IC - done (found exhaust leak and major heat soak) -install new coilover suspension - done -install new fuel pump and fix floater - done -install short shifter - done -fix exhaust leak- done -reroute waste gate open dump - done -install new cat-back exhaust - done -new 1.06 hot side - done -new V-mount IC setup - done -fix minor vacuum leaks - done -new injector resistors & wiring - done -a good tuning - done (FINALLY) -install and wired up new water temp gauge - done -fix injector leaks - done -install new front rotors and pads - done -change plugs - done -fix broken door locks, handles, etc. - done -retrofit projector HID headlight - done relocate battery to rear - done Still to do list -install rear rotors and pads -install alum. AST -new paint job -cut stock hood, install hood vents -install Mazdaspeed GTC front -install remote entry -sound system/headunits -NEVERENDING maintenance, and upgrade
	![]() 1994 RX-7 PEP - (SOLD) 1993 RX-7 R1 - (under the knife) 1973 RX-3 13b 5 speed (DGRR 2011- 1st in class)  |
