| View Poll Results: What oiling setup to use for racing | |||
| Leave it stock and run the right engine oil |
0 | 0% |
| Leave it stock and add some pre-mix |
8 | 53.33% |
| Disable the metering pump and pre-mix |
6 | 40.00% |
| Other - I have posted a better idea |
1 | 6.67% |
| Voters: 15. You may not vote on this poll | |||
tumor-syphilis-itis-osis
I run premix and the omp. (85 with a 12a) 128:1- The way i see it if you only run premix you are taking a risk that you will always remember oil in the gas at the proper ratio. Same running only the omp, if it fails or clogs without you knowing for a while it can cause the same issue.
82 300d 82 Gsl 84 b2200 Diesel 88 gxl |
