#11 | |
Don Mega
On holidays now, so start of next year will get back into testing and updates ![]() I'll fit up my new tires and the camera and take some video of how she goes, currently its on 26.3psi or 1.8bar gauge boost pressure. I have run WM50 for the last 2 years, logical progression from water really. I did allot of my own tests on a host of fluid mixtures, verifying old test reports and found in my own case that WM50 (50:50 by mass, not volume) works the best for me. I don't disclose the WI rate exactly (something I keep for my customers) but its "high", and it needs to be to run this level of boost pressure and certified performance on the VBOX ![]() Last year I did tests on 30+psi but was not overly happy with some parameters for long term use, last month I finally got around to re-engineering some system set up parts and now its much better as a long term proposition. All on the same 13B-REW I have been running for 3 years and its not ever been touched! (testament to reliability of water injection). This set up will easily do 2.5bar gauge boost pressure or ~36psi on normal BP Ultimate Petrol. What cant be conveyed over the internet is the speed of the way it is now on ~26psi! it flat out hauls!
