Old 12-01-2011, 02:33 AM   #11
Originally Posted by JhnRX7 View Post
2012 Plans
Next item on the list will be a front splitter for the track. I am going to pick up a 4'x6' piece of Alumalite from a local supplier and use that as the main material. The other option is making the splitter out of wood, but I am going to try out the Alumalite first. This will be a consumable item that WILL get damaged so using the alumalite or wood is preferred over more expensive carbon fiber for now. Im starting to work out a plan to fabricate brackets that will not interfere with the ducting that I already have in place.
Alumalite:
Hey John, not sure how much attention you paid to my belly pan last time we at the track, but I gotta say, I was surprised with how rigid it was when all was said and done. I used some plain 5052 .063 aluminum. There are a string of bolts around the front bumper, it travels all the way back to the subframe, and has a few pickup points in the center. When it's all snug and in place, I was surprised. I was expecting the need to box in some of the larger unsupported sections by riveting C channel in place, it just wasn't the case. I have no experience with the cored AL pieces, just the standard flat sheet.
After the suspension work I will need to get a new alignment. I plan on running slightly less camber this time around. Then I will be getting a corner balance as well.
This we should chat about
Aaaaaan tuning as well, correct? When I get some more details on dyno rental I will let you know. I'm sure something can be arranged though.
:drool: Beautiful as always.
Hope all is warm where you are, it's dropping into the 30's up here
ducting, ducts, fd3s, jhnrx7, track
