			 Home-brew Rotary
				Rep Power: 18 ![]()  |
				Info on Filters. Oil, fuel, air.
			This has been of interest to me for awhile.
			I think it would be good to have a thread about this. I searched a little bit but found nothing. But anyway lets get started. Oil filters: I've cut some apart to see how there designed inside. A Mazda, Purolator, and a Fram filters. (The Fram is off some other car but the other two are off a rotary.) ![]() Mazda. (Soaked with oil.) ![]() Purolator. ![]() Fram. ![]() IMO, I like the way Mazda and Purolator are designed, but Purolator is cheaper ($). Anyone have any more/other info on filters? Feel free to share.
	'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily.  |
			This is what ive seen, fram shouldn't be in this at all, it doesnt have a check valve in it so the way they mount on a rotary once the oil stops flowing all that dirt and particles the filter has caught now leak back into the motor. Fram for a rotary sucks
			purolator or mazda would be the only filters id run both are very good, im sure the purolator is a little better then a oem filter but i wouldn't swear to it. as for fuel i run the ones i get from mazda and a mr gasket one from advanced (im carb'd) and oil castrol 20-50 change it every 3,000 miles, 2,000 if you beat on it a lot. All oils I've tried, castrol 10-30 broke down to quick, supertech (walmart) 20-50 also broke down to quick i use it as break in oil so at 500 miles pulled the plug and it was like water, those are the ones ive tried, stay with castrol 20-50 theres a reason its on the race cars
			![]() 85 rx7 gsl-se - AA tags/ never ending project will never run Last edited by IH8DSM; 01-24-2011 at 09:02 PM.  |
				Rep Power: 0 ![]()  |
			Interesting.  How many miles on the Mazda and Puralotor?  Were they taken off same motor?
	Rodney
				Rep Power: 10 ![]()  |
			I like Mobil1 oil filters.
			What I need to do is order a case of Mazda oil filters and be done with it.
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
			that doesnt look like a purolator for a mazda but i could be wrong,
	![]() 85 rx7 gsl-se - AA tags/ never ending project will never run  |
				Rep Power: 22 ![]()  |
			I use Beck/Arnley
	1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5  |
		#7 | |
			 Rotary Masochist
 While I will agree that Fram has a poor reputation and I avoid them, your scenario is not accurate. The check valve only ensures that oil is held in the filter to avoid dry starts. The "dirt and particles" that might be entering the engine from the cooler come in through the bottom of the rear iron, up the iron to the middle of the filter, through the media, out of the filter, and down to the rear main. The only way for the bad stuff to get to critical parts of the engine is through the filter media (whether the engine is running or not). There is no possible way for it to "leak back into the motor".
	_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI  |
			 Home-brew Rotary
			The cut-up Purolator filter actually might be off some other car as well.
	I cut-up the Purolator and Fram filters years ago. Btw: I never liked Fram.  |
		#9 | |
 Also any "dirty oil" from the inlet is also poised at the bypass valve (directly below it in the pan) ready to contaminate your cleaned oil if the bypass is opened during cold start-up. If you have a direct reading gauge you will see this happen at about 105-110 PSI (3rd Gen). During warm-up it is important to try to avoid this. Barry  |
		#10 |
			 Waffles - hmmm good
			Ok, heres link to a very well done study done by someone thats very methodical
			to say the least. The original version was done almost 10 years ago but has been updated since. This guy covers almost anything you may end up discussing here. Read up, its a great resource and learning experience. This is one of the reasons I started using Mobil 1 filters instead of paying more for K&N and so forth. This is a link to the complete study. http://minimopar.knizefamily.net/oilfilters/index.html Heres a link to the good stuff on general retail filters. http://minimopar.knizefamily.net/oil...reference.html
	1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00  |
		#11 |
			 Home-brew Rotary
			^Good find. Thats cool.
	Here are some Purolator filters for the rotary. A Pure One and a oil soaked Premium plus.
		#12 |
			 Hi
			Too bad there's nothing on Canton filters in there.
		#13 | |
			 Rotary Masochist
 I knew I would get that wrong. ![]() Any dirty oil that is bypassed by either regulator is just falling back into the pan with the rest of the dirty oil. Not sure I see the issue there.
		#14 |
			Ok from what I've always seen oil comes through the big hole that's a thread stud that the oil filter attaches to it goes through that big hole and is forced through the filter and then to drain after that which means all the particles are still on the inside of the filter so when your car turns off it flushes back into the motor. I could have this completely backwards but for some reason I thought this was correct.
		#15 |
				Rep Power: 20 ![]()  |
			From 2-2 in the FSM it looks like the freshly cleaned oil goes directly to lubrication of parts.  I doubt very much the filter is cleaning oil just to be dumped back in to the oil pan.
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
