Old 10-21-2010, 09:54 PM   #1
Mateepay
Mateepay is on a distinguished road
the car runs and drives fine anyway to tell wether the trailing is good?
Mateepay is offline   Reply With Quote
Old 10-21-2010, 10:46 PM   #2
FC Zach
FC Zach's Avatar
If you have an OHM meter you can measure the resistance between the primary (+ & -) which should be around 0.1 on your coil but I'm not exactly sure on the specifics, if you have a Haynes it is in there.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 10-21-2010, 10:50 PM   #3
FC Zach
FC Zach's Avatar
If it hasn't worked since you purchased the car then there is a chance that the Yellow/Green tracer wire (i think green tracer) may not be connected, but then again you did state that the needle does jump. ? ? ? weird
Edit: The yellow/green tracer wire is the signal wire for the tach.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
