				Rep Power: 10 ![]()  |
				Wiper switches
			Is there anyone rebuilding these anymore?  I'm a little tired of my toggle switch.  At this point a functioning wiper switch would be a luxury.
			Or how about the the relay numbers and that old write up?
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
			 Compression Tester Man
				Rep Power: 17 ![]()  |
			Perfect and awesome.
			Thanks much If anyone is wondering, the part numbers given are still good, the prices are a little outdated though
		#4 | |
			 GTUs
				Rep Power: 0 ![]()  |
 I think for $75 each plus shipping. I'll give you his info if you want it via PM.  |
			Sure, thanks man.  I sent him a PM over on the ole' evil forum and never got a response.  Figured he wasn't doing it anymore.
			 GTUs
			 I've been Wankeled!
				Rep Power: 16 ![]()  |
			Can he fix the "I work when I want to" clock issues with the idiot clusters?
	1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place 1974 Rx-4 all original 27,000 miles 1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place  |
				Rep Power: 18 ![]()  |
			Is the problem with the wiper switch similar to the problem with 1st gen lighting switches?  We have found that by shooting them full of Electrical Contact Cleaner (like 6 bucks from Autozone for a huge can) and working the switch back and forth for a bit, cleans the contacts up and gets them working again.  No parts need to be removed to do this.
			Might not apply to this issue, but I thought I'd throw it out there for you just in case. ![]() .
	"Learn from the past, or it will become your future...." '85 GS 12a + LSD/Sterling carb/Respeed coilovers/Respeed front swaybar/Respeed adj. rear spring perches/Illuminas/Bilsteins on rear AutoX vids @ http://www.youtube.com/user/Kentetsu1  |
		#9 |
			The problem with the wiper switch is typically bad relays in the switch itself.  Occasionally, cleaning the contacts seems to work, but a lot of people report only temporarily.  The permanent fix seems to be desoldering out the old relays and soldering in new ones.
	Jerry 1991 Mazda RX-7 Turbo - the current project/money pit  |
		#10 |
			Definately interested.  Wanted one a year ago but there always seems to be things more important that need my attention which is why right now I'd rather just pay for it than spend the time dicking around although I am about to order the relay
		#11 |
				Rep Power: 20 ![]()  |
			I have the same issue, what is the cause of this problem. Before it completely stopped working I assumed it was a bad connection at the harness so i removed it, checked for tight connection, reinstalled, and still had the same intermittent "I work when I want to" problem. I have become used to this problem and have never really cared to fix the issue but am sill curious about the cause of it
	1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4  |
		#12 | |
	1986 Sport: 132k miles, 5A (Sapphire Blue Metallic), Tokico Blues, Racing Beat Springs, Custom LED tailights (only S4 LED tails in the world), SSR Mark II, Racing Beat exhaust, S5 black interior, Rotary Resurrection rebuild at 120k miles Community Service Manual RotorWiki "Imagination costs nothing; we could build square locomotives or fly to Mars" - Felix Wankel Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."  |
		#13 |
			I did that too, worked quite well... then I installed too much crap in my regular electronics area (gauges, etc).  Now my clock continually reads 1:00  Sometimes it will work, but then something happens and it will reset to 1:00.  I think it's a ground issue I caused, which is to be expected with the time constraint I was under when I installed the gages.
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
		#14 |
			How hard is it to resoder the wiper switch?
		#15 | |
			 400WHP or bust
 Not hard at all, fixed mine in just over anhour with removal/install time.
	1986 GXL- Being built with a 13B RE... http://www.rotarycarclub.com/rotary_...ead.php?t=9602 1986 Base-RB Exhaust, HKS filter, Solid Aluminum motor mounts, S5 TII motor, ACT Clutch, HKS SSQV, Light Weight Flywheel, Haltech E6X, 720cc 2ndaries, Koni Yellows, Tein Springs Koyo Rad, 250 WHP 230 FTLBS Stock turbo, and stock IC at 10psi. RIP!! The daily bitch- 1995.5 Toyota Tacoma- Trueflow airfilter, and Bilstein HD shocks. 2009 Toyota Corolla "S" TRD Filter... 40MPG  |
