Old 04-21-2010, 10:19 PM   #1
sen2two
KTEC
sen2two's Avatar
added a 12v plug
So i added a 12v outlet in my car for various reasons. I checked it with a multimeter at the plug and its getting correct voltage, but its popping the inline fuse i put in.
I just got a simple connector and plugged it into the power side of the auto seatbelt fuse slot since I no longer have them in the car. I chose that one because it gives constant 12v power. I ran a wire to a inline fuse before reaching the 12v outlet. The 12v outlet only has two wires on it, power and ground. I grounded the one to a near by bolt. And ran the power wire from the outlet to my power source.
It pops the inline fuse pretty much instantly if i have something plugged into the outlet.
Any ideas?
what I have:
What I had:
Old 04-21-2010, 10:49 PM   #2
My5ABaby
My5ABaby's Avatar
What size fuse?
Community Service Manual
RotorWiki
Old 04-22-2010, 08:34 PM   #3
sen2two
KTEC
sen2two's Avatar
well, i tryed a 15amp and a 20amp. The seat belt fuse slot is a 30amp, so that might be the reaosn. But then i tried a few other slots that only have 10-15 amps. They still bust the 20amp fuse. I then tryed the 12v power from my ignition wire, and still popped the fuse... I checked my ground coming off the 12v outlet for continuity, just to make sure its a good ground. Yupp... good ground. So whats the problem???
what I have:
What I had:
Old 04-22-2010, 09:01 PM   #4
My5ABaby
My5ABaby's Avatar
I put in an Add-A-Fuse with a 15amp fuse for my extra outlet and haven't had any problems running a phone charger. Wish I could help more.
RotorWiki
Old 04-22-2010, 09:22 PM   #5
sen2two
KTEC
sen2two's Avatar
add-a-fuse? is that the thing that looks like a fuse but has a power wire coming off of it? seen that at autozone, but i was unsure it it would make a difference?
what I have:
What I had:
Old 04-22-2010, 10:27 PM   #6
My5ABaby
My5ABaby's Avatar
Yeah, it's basically a fuse holder with a wire coming off of it.
RotorWiki
Old 04-22-2010, 10:34 PM   #7
Have you tried different plugs? That could internally shorted. Other than that the outlet's fucked
Old 04-23-2010, 02:31 PM   #8
sen2two
KTEC
sen2two's Avatar
what do you mean by "different plugs"?
what I have:
What I had:
Old 04-23-2010, 05:40 PM   #9
try a cell phone charger
then try a small inverter
then try am ipod adapter
then try a 12V ballscratcher
then try the sweedish grip suck machine
then try.... well you get the idea
Old 04-23-2010, 06:06 PM   #10
RotorDad
Big Ugly
RotorDad's Avatar
Interesting way of getting your point across.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 04-24-2010, 10:46 AM   #11
sen2two
KTEC
sen2two's Avatar
Actually i tryed a few different plugs... And i tested the inverter in 2 other cars, it worked fine.
what I have:
What I had:
Old 04-24-2010, 11:15 AM   #12
My5ABaby
My5ABaby's Avatar
Do you have the ground and power wire connected to the correct spots on the plug? IIRC the power is the center one and the ground is the whole outside portion.
RotorWiki
Old 04-24-2010, 01:45 PM   #13
You would be correct
