#16 |
Rep Power: 21 ![]() |
They might be similar in running temperature but something tells me there is a reason the rx-7s came with such a large oil cooler where many piston engines simply do not.
#17 |
Yes they put a lot of thermal energy into the oil, that's what the oil cooler is for, but as long as the temperatures aren't any different, then the oil won't care. There's plenty of piston engine car with oil coolers too you know.
#18 | |
Rep Power: 20 ![]() |
#19 |
Reliable Source
additives
#20 |
however, the Renesis continues to have trouble with normal oils foaming. It's give and take, there's still ways to keep oil from foaming.
#21 |
tumor-syphilis-itis-osis
I use that in my diesel didn't even think to stick it in the 7
82 300d 82 Gsl 84 b2200 Diesel 88 gxl |
#22 |
I sell oil as well as fleet service. Archer Oil out of Omaha,Neb. I run 20/50 hi torque in my turbo and 5/30 syn in my race n/a engine. Most diesel oils are for diesel engines with no egr system. The late model diesel motors have this egr sys as a fed requirement. Do more home work. get info from more than 1 salesman. The oil company that I represent has oil analysis. I've asked the folks that have been testing for years. Do your home work before you commit.
#23 |
crash auto?fix auto
What do you expect to gain from running diesel formulated oil that couldn't be gained by just running a heavier oil like 20w50?
Personally, its not like the rotary suffers from any kind of premature bearing failure or anything that would require re-thinking the contents of the lube system - outside of modding passages and teardropping orifices on the e-shaft etc. But I highly doubt its going to kill anything either? |
#24 | ||
Rep Power: 10 ![]() |
#25 |
Rep Power: 22 ![]() |
My good friend ONLY uses Rotella in his Subaru's (STi and Turbo Legacy). Apparently they all swear by it as well.
I never thought to use it in a rotary though.
#26 | |
REALLY... Do you think we're stupid enough to listen to some saleguy??? Please go away troll. -Ted |
#27 | |
#28 | |||
#29 |
Ash content would be less of an issue if running aux injection since the engine is always being steam cleaned. I had been running mobile 1 15/w50 which was designed for performance cars that needed extra antiwear additives. I'm not sure what the ash content was but it seemed like the oils with extra antiwear had more ash. Walmart stopped carrying the oil i used and it seems like all the oil formulas are going green which have much lower antiwear properties. These oils could cause us to see more bearing problems pop up. Not to mention our expensive turbos can use a good quality oil. At least the desiel oils don't appear to be removing all the stuff giving extra protection. I'm still debating on what oil i want to use. I like synthetic because it seems to run a little cooler, and doesnt coke up the turbo bearings. But it's also more expensive, so it may be just as well to go back to "dino" oil and change it twice as often. So many choices. If you google it, you'll see the topic of antiwear additives is an issue on tons of car forums.
500+ HP thanks to: ![]() Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
#30 | |
