Old 11-11-2009, 09:54 AM   #21
I like the crush washer idea. Have you tried looking @ either GoodRidge or McMaster?
For the next engine I build I think I'm going to take your infered advice and skip the metal gasket, use the o-ring and the teflon piece as well and see how that works out. When this engine comes out in a month or so I'll pull the front cover, see if the 0-ring is still there. If not, replace the cover sans gasket and see if the oil pressures are any different.
I do disagree that this is not worth it for a street car. In my opinion this would be better for a street car than a race car becuase of the idle oil pressures. I would like to see oil presure @ idle consistantly be above 25psi to keep the jets in the e-shaft opened at all times. This promotes cooling of the internals more during extended idle periods which a street car sees more than a race car. Just my $.02 though.
