Old 08-01-2009, 01:38 PM   #31
Flooder
Flooder's Avatar
Flooder is on a distinguished road
550/1600 seems like a huge difference. Wouldn't the transition be really rough?
I've got a pair of 680cc injectors and a pair of 1000cc injectors for sale if you're interested .
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 08-02-2009, 12:24 AM   #32
Haltech has no problem handling it.
In fact, majority of Haltechs run this combo.
I know Microtech used to have a problem firing this combo.
Old 08-02-2009, 12:25 AM   #33
Originally Posted by rx7mechusa View Post
Wondering about using FMIC vs Upgraded TMIC i found an ARC TMIC for a fairly good price wondering if this would work with the hp im trying to get to?
Personally, TMIC is a waste of time.
The FMIC is always superior with the exception of cost and complexity of the install.
With the $100 eBay cores (bar-n-plate), it's cheap enough almost every FC owner can afford it; the hard part is the pipes and the throttle body adapter.
Old 08-02-2009, 12:32 AM   #34
I am looking into some suspension stuff now i had originaly put a set of Tein Flex on order but i cancel'd them because i found a better price on them on another website also was wondering what everyone thinks of Ksport, Tein, Cusco
Almost anything out there (from Japan) is okay.
I like Tein and Cusco myself
Most street driven cars don't need all the fancy adjustments most of those systems offer - it's a waste of money.
Tokico Blues + aftermarket springs are usually fine for most applications.
Personally, I like Koni dampers with custom housings for the FC.
(Koni is made in Europe - not Japan.)
Koni yellows offer great adjustment (continuously variable - not detents; not necessarily good for beginners) and can be custom valved if need be (for serious racing) - this is overkill for the street.
Cheap adjustable are KYB AGX's (great for the money + adjustment).
Retrofit coilovers are offered by Ground Control.
You can run whatever spring rate you want to custom your ride height.
Old 08-02-2009, 01:50 PM   #35
rx7mechusa
no no come on start plz?!
rx7mechusa's Avatar
rx7mechusa is on a distinguished road
Awsome thanks i have the greddy elbow and pipes at the house just would need to spruce them up a bit and i have another interesting problem i want to keep my P/S and A/C as this is not in any way shape or form going to be a "race" car. And i think if im creative enough i can run the pipes to allow this but has it been done? Thanks for the info on the suspension as well Ted.
US ARMY-OH 58D(R) Helicopter Mechanic
Cars-
1988 10th AE
1993 Nissan Pathfinder (off road fun truck)
1999 GMC Suburban (10thAE personal transportation)
rx7mechusa is offline   Reply With Quote
Old 08-03-2009, 11:12 AM   #36
MaczPayne
Bah!
MaczPayne's Avatar
It can be done, you'll have to use a little ingenuity in the routing. The older HKS and Trust FMIC's were routed so that you were able to retain both A/C and P/S
Johnson
TA FC in the works!
Old 08-03-2009, 02:29 PM   #37
Flooder
Flooder's Avatar
You can do it, its just all custom work. You might as well do a v-mount setup at that point for better cooling and less turbo lag.
AZRX7.COM
Red 1990 GXL(SOLD)
