Go Back   Rotary Car Club > REGIONAL FORUM > Southeast > North & South Carolina
North & South Carolina Mazda Rotary Car Club of North & South Carolina
Old 02-15-2009, 09:33 PM   #1
takahaski.r
rotard
takahaski.r's Avatar
takahaski.r is on a distinguished road
my first build!!
well i have had the car for almost 2 months now...ive only driven twice up an down my street. on the day i was going to have it registered it started smoking heavily,so i went online to see what i could gt as a response.
blown coolant seals. so i went with it knowing the engine had to be torn down.
not knowing anything about rotary engines i panicked and tried to get some one to help me through it,so my savior toby aka novice rotary tech
aided my call.
he arrived to asses the damage and confirmed the coolant seals.
so from tear down to back up ill post.
the car at day 1
2 weeks after
engine tear down
discovery of wroughted coolant seals that lead to seal failure.never let your car sit too long with water in it, previous owner also ran nitrous threw it
new housing and other new parts
pissed off?being that close to a rotary, id say youd be pist-on
takahaski.r is offline   Reply With Quote
Old 02-15-2009, 09:43 PM   #2
takahaski.r
rotard
cleaned the engine bay with toothbrush....seriously
rotor sitting in new housing thanks ernst (rx7world)
engine reassembled with toby's god like rebuild technique!!
installed air separator tank from gp sports.
had to make new omp lines from small engine fuel line.
also had to modify adapter to fit apexi air filter.
had to make plug wires, accel 8.5 spiral wires
now im waiting for the remainder of my parts to get here.
himni racing solid urethane engine mounts
rt racing silicone rad hoses
koyo rad
need the injector grommets?!?!?
stainless clutch line
Old 02-16-2009, 05:35 PM   #3
88turboii
destroy, rebuild, repeat
88turboii's Avatar
cool, good luck with putting it all together, you know its an RX-7 when you have spent more time fixing it than driving it haha
your car looks just like tobys too
Old 02-16-2009, 09:22 PM   #4
takahaski.r
rotard
toby and i were thinkin about having a mini meet upon engine install
Old 02-19-2009, 03:05 PM   #5
RotaryRoadRage
RotaryRoadRage's Avatar
RotaryRoadRage is on a distinguished road
look's good man.. GL with the project..
chris
89 TII black on black
Gamer tag - graveconditions
RotaryRoadRage is offline   Reply With Quote
Old 02-19-2009, 03:09 PM   #6
Originally Posted by takahaski.r View Post
AHH! An orb! Your garage is haunted.
Old 02-22-2009, 10:28 PM   #7
takahaski.r
rotard
engine is back in and fired up
Old 02-23-2009, 09:54 AM   #8
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Really? You got it started? I want details. Call me.
Old 02-25-2009, 05:35 PM   #9
takahaski.r
rotard
its done! yay....rotary meets here i come!!
Old 02-27-2009, 08:39 AM   #10
88turboii
88turboii's Avatar
how does she run? did you find a plug for that coolant sensor hole?
Old 02-27-2009, 03:31 PM   #11
N.RotaryTech
Home-brew Rotary
For some reason I believe he has a TII center iron.
Look at the pictures with the center iron in them.
In the 1st post, look at the last picture, there is a hole right under an next to the oil filler neck hole toward the front of the engine. Isn't that where the knock sensor goes on a turbo motor?
Just wondering if the ports in the center iron of turbos are different than the center iron ports in n/a's.?
Are they smaller?
I should know this by now.
Old 02-27-2009, 07:57 PM   #12
88turboii
88turboii's Avatar
where did the engine come from??
Old 04-05-2009, 09:05 PM   #13
takahaski.r
rotard
figured it was time for an update
new wheels,hood,thanks jamin. i still owe you.and custom front lip
tII calipers waiting to be put on.
Old 04-05-2009, 09:06 PM   #14
takahaski.r
rotard
also forgot Savannah side spat things
Old 04-06-2009, 12:11 AM   #15
88turboii
88turboii's Avatar
looks nice!
