Old 12-18-2008, 09:10 PM   #1
fc nut
member
fc nut is on a distinguished road
Post fuel smell when idling
the smell is coming from the pass side of the engine.i can't see any fuel leaks.i only smell it when it idles.i've read that engine fires are common,could it be the pulsation dampner?
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
Old 12-18-2008, 09:15 PM   #2
Could be, replace it anyway. Who knows when it was last checked, much less replaced!!
Old 12-18-2008, 09:16 PM   #3
check before replacing.....could be an injector.....could be a really rich exhaust.....could be a bunch of things....get under the hood and get back to us
Old 12-18-2008, 09:23 PM   #4
fc nut
member
i've heard of a modification to remove the dampner and replace it with a banjo bolt,does this work?
Old 12-18-2008, 09:27 PM   #5
rx7 FC TII
rx7 FC TII's Avatar
theres always been a huge debate on that. i think it really comes down to personal preference.
do some searching and you can find tons of info...if not on this forum then the "other" one will
Old 12-18-2008, 09:31 PM   #6
fc nut
member
Post
i was just on rx7club and someone talked about it might cause a uncontroled rich or lean mixture.
Old 12-18-2008, 10:13 PM   #7
farberio
farberio is on a distinguished road
The banjo bolt is the shitty way of doing it, replace it correctly.
farberio is offline   Reply With Quote
Old 12-22-2008, 07:54 PM   #8
fc nut
member
Post
i took a good look at my 7 and what i could see is the upper intake manifold gasket is leaking.it's too damn cold right now, so i'm going to take care of it this weekend.it's supposed to be warmer this weekend.
Old 12-22-2008, 08:32 PM   #9
Fidelity101
Reliable Source
Fidelity101's Avatar
Do your eyes burn when you have the hood open with the car idling? stock exhaust manifold or recent manifold change? it sounds like you have an exhaust leak. If you cant find it, seafoam can help find it for you.
a leaking intake gasket could give messed up AFRs and confuse the electronics because air is bypassing the sensors so the readings will be false thus the engine runs odd.
My Rx-7 Vids
Old 12-22-2008, 09:40 PM   #10
My5ABaby
My5ABaby's Avatar
Eh, nothing wrong with the banjo bolt. I'd rather have a couple rich spots (assuming that's even true) then have my car catch fire.
Community Service Manual
RotorWiki
Old 12-22-2008, 10:17 PM   #11
fc nut
member
Post
i do have a slight exhaust leak at the manifold gasket.i have to retap the hole this spring. i can see fuel deposits on the area where the intake gasket is leaking.
