Old 11-28-2008, 04:19 PM   #1
ArtOfRuin
Magic Spinning Triangles
ArtOfRuin's Avatar
ArtOfRuin is on a distinguished road
Premix at the pump
The next time I take my FC to the pump, I plan on pouring in some 2-stroke premix. About how much premix should I add per tank? What type of premix do you guys use?
I was thinking of using Royal Purple 10W30 and premix once spring (racing season) comes around, but I'm sticking with 10W30 conventional for the winter.
Stock S4 N/A 13B. The oil metering pump is in place and working.
'87 Mazda RX-7 GXL: Solo E Stock-bound
'98 Subaru Impreza: The Daily Beater
ArtOfRuin is offline   Reply With Quote
Old 11-28-2008, 04:22 PM   #2
I generally use about 1oz per gallon.
Old 11-28-2008, 10:37 PM   #3
mazda_wes
mazda_wes is on a distinguished road
every time you roll over a couple of gallons, add a couple of ounces. 1 gallon of gas/1 ounce of oil is the rule of thumb.
why do you need to premix if you still have the OMP?
mazda_wes is offline   Reply With Quote
Old 12-10-2008, 12:59 PM   #4
Roen
Evil Club Mod
Roen's Avatar
If you have the OMP still working, 3-5 oz per TANK, is all you really need
Old 12-10-2008, 05:30 PM   #5
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
I second this.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 12-10-2008, 08:31 PM   #6
Rotary13B1
Rotary13B1's Avatar
Rotary13B1 is on a distinguished road
I only use the best for mine...
1oz/gal
RCC Vendor & Supporter!
Rotary13B1 is offline   Reply With Quote
Old 12-14-2008, 10:23 AM   #7
farberio
farberio is on a distinguished road
1oz/gal
No you don't, Amsoil Interceptor FTW!!!
I just got done researching both of these...while Idemitsu is a very very good choice, Amsoil uses more cleaners and makes your engine nice, shiny, and almost carbon free.
farberio is offline   Reply With Quote
Old 12-14-2008, 10:24 AM   #8
farberio
+1, 1oz per 1 Gallon is the measurement for non OMP vehicles.
Old 12-14-2008, 11:32 AM   #9
Keep in mind guys - as it always in when premixing anything (cars, bikes, lawnmowers, etc) you add the oil to the tank FIRST and then add the gas... otherwise it won't mix evenly. You use the pressure from the gas pump to slosh the oil around and mix properly.
If you are using the stock OMP you really wont need more than 3 to 5oz like others have mentioned. Going more than 100:1 is a bit much....
Old 12-14-2008, 07:52 PM   #10
My5ABaby
My5ABaby's Avatar
I use the Wal-Mart cheap stuff. Let's be honest here, unless you're running some obscene hp (or something...), I really really doubt you could tell the difference after 100,000 miles between mine and the stuff that costs 5x as much.
Community Service Manual
RotorWiki
Old 12-14-2008, 09:12 PM   #11
NitroRacer
NitroRacer is on a distinguished road
i use wal-mart stuff as well. 1oz/2gal. and im at 417whp.
NitroRacer is offline   Reply With Quote
Old 12-15-2008, 05:27 PM   #12
farberio
Not as its running no, you notice if your the one doing your own rebuilds. Your parts come out clean as opposed to carbon coated.
Though, if you could collect all that carbon and make Apex Seals out of them...
Old 12-15-2008, 05:39 PM   #13
I use the Penzoil Marine Pre-mix
Old 12-15-2008, 05:41 PM   #14
firzen
If it has TCW3 on it, I try it. Haven't found my favorite yet, however.
Old 12-15-2008, 07:44 PM   #15
My5ABaby
My5ABaby's Avatar
Probably because there's hardly any difference.
RotorWiki
