Old 12-25-2014, 01:17 PM   #16
Originally Posted by mazpower View Post
I have yet to fry any wheel bearings or warp rotors even on slowing the Miata down on the track or when playing on the street.
Sweet! Good to hear.
I believe the Miata has, and in know the FD has sealed ball bearings. The FC runs a taper needle bearing. The former is much less susceptible to heat. Also, running a one piece rotor helps tremendously as well.
I need to change the bearings, repack with a very high quality grease, reduct the front end, and then go play on the track and see what happens, I'm fairly confident I can get this issue under control. Problem is thee aren't many FC guys running a 13.25" two piece front rotor with hitemp track pads
Ok that explains it. I always thought two piece rotors cooled better. I thought that was one of the advantages.
Sounds like you need to swap over the hubs from either a Miata or FD lol.
Here are some charts with info about Winmax pads. I'm thinking about the W3.
Old 06-17-2016, 09:31 PM   #17
hozzmanrx7
7Club Refugee
hozzmanrx7's Avatar
hozzmanrx7 is on a distinguished road
http://www.rotarycarclub.com/rotary_...ad.php?t=18989
"he's a tool that moved from being an abusive moderator to a troll that acts like a tool to get his attention now."
John (Jon) Michael Borry = RX7roller02 = skydivr7673 And that's the truth. http://rotarycarclub.com/rotary_foru...t=17659&page=7
hozzmanrx7 is offline   Reply With Quote
Old 06-19-2016, 03:41 PM   #18
I ended up buying Endless MX72 pads front and rear. I just did the RZ brake upgrade this winter and got it back on the road a few weeks ago. So far I love them but I'm still getting used to not having ABS anymore too. These pads don't squeal and so far they've stopped great.
