Old 07-12-2014, 07:44 PM   #46
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
Originally Posted by C. Ludwig View Post
I wouldn't want the sensor bulb plugging up the middle of the bolt where oil needs to flow.
agreed, guess I should clarify... I just seen on 7 club a party about drill/tap the bango, and its in the way quite a bit, another poster suggested, drill tap for 1/4 npt vs 1/8not (or bsp depending on sensor) then swedging it to the sensor size, this pushes the sensor probe out of the way so it's not in the flow nearly as much as before...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 07-14-2014, 03:01 PM   #47
I agree. I was even contemplating a PLX system which can tie in to the OBDII to show coolant from the ECU, and oil temp from the PLX on my phone (torque app). Their sender is pretty long, and unless it can be spaced out there is obvious worry of restriction.
Autometer has this:
http://www.jegs.com/i/Auto-Meter/105/2259/10002/-1
Designed for cylinder heads but same range as the other sensors so it fits all short sweep temp gauges. Would work good in a standalone app where custom resistances can be calibrated in, or if using autometer gauges is acceptable. I didn't really want to add an actual gauge to the RX8 (down by shifter), especially since I use my phone to watch coolant temp already when at track days.
Old 07-16-2014, 11:47 PM   #48
Verocious Motorsports says I can't buy that fitting in a 10AN, and I found what I think is the same thing on Amazon, but it says it has 1/8 FPT. Have you guys heard of FPT before?
http://www.amazon.com/Fragola-Alumin.../dp/B00GV1JCOM
Old 07-16-2014, 11:52 PM   #49
chibikougan
chibikougan's Avatar
Usually means female pipe thread. So the side hole will fit 1/8 NPT
Definition of pipe thread acronyms
NPT National Pipe Thread (tapered)
FPT Female Pipe Thread (interchangeable with NPT)
FIP Female Iron Pipe (interchangeable with NPT)
MPT Male Pipe Thread (interchangeable with NPT)
MIP Male Iron Pipe (interchangeable with NPT)
IPS Iron pipe size (interchangeable with NPT)
PTF SAE short taper pipe thread
NPTF National Pipe Thread Fine (American National taper pipe thread for dryseal pressure-tight joints)
NPSM National Pipe Straight Mechanical (American National straight pipe thread for mechanical joints)
NPSI American National straight intermediate pipe thread
GHT Garden Hose thread
NST National Standard Thread (Fire Hose thread)
BSPT British Standard taper pipe thread (metric dimensions)
Old 07-17-2014, 01:23 AM   #50
Hmmmmm, alright. I think I'll go ahead and get one. Thanks!
Old 07-22-2014, 11:41 PM   #51
I got that fitting in the mail today and tried it out. Just putting the sensor directly into the 1/8NPT port, it blocks too much of the oil flow. Over half, probably even 3/4 of it. So I'll either figure out some sort of adapter to put it out some, tap the thermostat, or keep it where it's been.
Old 07-23-2014, 12:18 AM   #52
Prodigy
Prodigy's Avatar
http://www.amazon.com/gp/aw/d/B004RC...ref=mp_s_a_1_2
user something like this to storage it out if you want, just need to make sure you get the right thread on both sides for your application. it sound space the sensor atleast 1/2 out if not close to an inch, while still allowing for it to read the temp.
J.
Old 07-24-2014, 08:15 PM   #53
The only problem is the sensor fits right into the port, so I'd have to get a 1/8x1/8. I'm not sure if that's possible lol.
