Old 07-22-2013, 06:43 AM   #31
thanks Brian. Wait til you see the color thats picked out.
Old 07-24-2013, 11:47 AM   #32
This color!
Old 07-24-2013, 03:17 PM   #33
leknaw
leknaw's Avatar
leknaw is on a distinguished road
Great find!
Great job so far! Digg the color big time!!!
leknaw is offline   Reply With Quote
Old 07-28-2013, 09:47 PM   #34
Busy weekend working on the claptrap. Started boxing the frame i had to clearance for the FC subframe. I learned I hate welding upside down. Like, a lot.
Started stitching up the engine bay, which proved a pain. Lots of rust to contend with. Steering clearanced in the frame rail, but a little rust to remove forward of the cut. so i need to work on that still.
Then found one of my FB overskin templates, so i modified the Rx2 top to be an Rx7 for obvious reasons. Need to find the other one to the do the driver's side. I also might go ahead and smooth over the welds so it looks nicer. But OCD.
Old 08-01-2013, 07:00 AM   #35
Since you had to build 'outriggers' to mount the FC subframe on the RX-2, I wonder how close to 'bolting in' it would be on my Cosmo. I think the Cosmo might actually be too wide.
Hmmmmmmmmm
Old 08-01-2013, 08:28 AM   #36
Hmmmmmmmmm
give me the the dimensions inside to insde and outside to outside and Ill be able to give you an idea.
Old 08-01-2013, 08:28 AM   #37
I need to get my hands on coilovers to get this car rolling around. The FB spring on FC strut hits the Rx-2 spring tunnel.
Old 08-01-2013, 12:26 PM   #38
I'll do some measuring tonight after work!
Old 08-01-2013, 06:58 PM   #39
Looks like 27" from center to center of the front rails.
That sound right?
Old 08-06-2013, 06:10 PM   #40
scored a set of shitty ebay coilover things from the pull a part which will allow me to get the car rolling around until i can afford coilovers for it!
Old 08-06-2013, 06:12 PM   #41
That sound right?
So i can't find my tape measure....
I'll keep looking.
Old 08-07-2013, 12:22 AM   #42
chibikougan
chibikougan's Avatar
Haha damnit that happens to me all the time. So I bought 5 someone already stole 3 of them.
The only person I know who loses his tape more then anyone ever. My Pah!!!!
I am totally going to scream Pahhhh! Like Khan! When I see him tommorow.
Old 08-07-2013, 08:58 AM   #43
Ran into some clearance issues with the engine. Got... creative
Old 08-08-2013, 04:07 PM   #44
in preparation for the move i had to get the car rolling. So here she is rolling! using some ghetto over sleeves until I get coilovers, and without the fenders since I had clearance issues with the giant FC tires I have.
There is a motor hiding in there too, but I'm not happy with using the stock FC mounts as it sits way too far back.
Old 08-08-2013, 05:15 PM   #45
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
I do believe you're going to need some flares with that. You'll probably need a wider rear axle to bring the back tires out to the same track width too.
Before you move the engine, put it on some scales to check your weight balance. The FCs had it so far back to give them a 50/50 weight distribution. I'd bet it probably helps an RX-2 in the same way.
