#316 |
Rotating Assembly
Yes, the FSM refers to the connector I'm referring to as the "test connector" in chapter 4. If you search the club site for "initial set connector" you'll find lots of hits but it is referred to as "initial set coupler" as you can see in this thread.
And yes, you ground the ISC whenever you are adjusting your idle or setting your timing. Otherwise the ECU will fight with you. Good to hear about the AFM. Bummer about the short.
![]() ![]() 90 S5 Vert. JDM Tii with BNR Stage1 turbo. Pineapple Racing street port. Bonez cat-forward. Corksport cat-back with Vibrant UltraQuiet resonator. RTek 2 wZeitronix w/b. HKS EBC. Vis CF Tii hood. 3000GT wing. Ground Control coilover kit with KYB AGX shocks. Red and Black leather RX8 seats. Corksport Odura lip & bumper caps, OEM Tii skirts |
#317 | |
#318 | |
Thanks for the heads up on the ISC and about finding my short.
Its definitely an intermittent thing with the short. Last week when I started having hot start issues I noticed that one time the whole engine sputtered in mid drive. The whole engine lost power just for a split second but then kept on driving. That and the engine compartment has felt warmer than it should...specifically around the main fuses. Probably the short making contact then not, making contact then not. Probably heating up the fuses but not burning it. Things I've recently messed with are the leaving my OEM O2 sensor wire unconnected. I'm using the simulated output on my Innovate and have it spliced in right at the ECU. But IIRC the OEM O2 wiring is a straight feed into the ECU. I don't think the O2 wiring routes through the main fuse. I've been testing my TPS but that has all been back-probe. I don't have an ASV on my engine, but I do have some harnesses dangling here and there.
#319 | |
I'm tapping into the green 6pin harness by the battery for my efan power. Does that feed into the EGI fuse?
[IMG] [/IMG]
1990 Vert/ S5-JDM 13BT (rebuilt but with issues I'm working out). Rtek N370 1.7, 550/800 injectors, FD fuel pump, RB REV TII exhaust, Tein springs and Illuminas Last edited by JustJeff; 06-23-2013 at 01:03 AM. |
#320 | |
Most (effective) electric fans need at least 20A of current. Almost nothing on the stock electrical system can support that kinda current with the exception of the starter... I will run dedicated power wires for electrical fans. Minimum 10-gauge wiring and as short as possible - through a relay. -Ted |
#321 | |
Sorry I should have been more clear. Here's the diagram I used for the efan
#322 | |
At least when the enigne is warming up the EGI fuse is fine. Popped a new one on, let it idle and warm up to about 170 and nothing to speak of. main fuses box isn't getting warm at all.
My idea had been to rig up a test light to plug into the EGI fuse location. I figure as long as there is a short the light is going to, well...light up. If I get in and start looking around and the light goes out while I'm handling something...well that would tell me the source of my problem. If it's an intermittent problem, that makes my idea much more difficult. Any ideas how to proceed would be wonderful. For what it's worth the engine sounds fantastic with the N350 AFM on....that's a plus.
#323 | |
Here is what I have found from looking at wiring diagrams about my EGI fuse. I have +12v IGN power for the efan tapped into the B1-08 Check Connector. The green 6pin. That harness sees current via the EGI fuse which goes through the Main Relay.
The only time I've had a problem with the EGI fuse is when I had the efan manually switched on for an extended period of time. Forgive my ignorance with electrical...I know just enough to be dangerous... Ted you mentioned using the starter for power. Are you thinking having fused/breakered power coming from the starter rather than the battery. Or the IGN? One thing to note from that diagram. I have not yet tapped into 1O pin for idle.
#324 | |
Well, now I've done it. I read about using a resetting fuse and a compass to track down where my short is. Only problem was the resetting fuse was resetting too quickly and melted the insulation.
The plus side is that I found where my short was. It was like I suspected. The +12v for the efan which was plugged into the test connector by the battery. That wire got pinched under the battery tray and rubbed till it had exposed wire. The melted wiring stopped exactly at that point moving towards the relay for the efan. Though it did not stop traveling down the harness side. It followed the wiring diagram perfectly, getting all melty along the way. It went from the 6pin (B1-08) through to the main relay (B1-02) and on to the EGI fuse harness. I started cutting into the harness to trace it back. It looks like the damage is isolated to just main relay harness, check connector wiring and harness and EGI fuse wiring and harness. I'll do more digging tomorrow morning. My biggest concern is that from B1-08 harness following the B/W wire back it then split. I haven't traced it back physically but I have looked at the diagrams. It's going to both the Main Relay (B1-02) as well as to (X-11) on the passenger side kick panel. At least from the digging I've done so far and looking at the diagrams..it's looking like I"m better off running new wiring than trying to replace the entire harness. It looks like that harness covers a lot of ground. Going from firewall on driver side (I'm assuming ending at the driver kickpanel?), across the front of the bumper and ending by the passenger side headlight. Lesson learned, now to fix my mistake...
#325 | |
So I dug around in my wiring and the damage isn't too bad. Gonna replace the Main Relay, gonna source new harness for the main relay and a new Check Connector. I don't really need the Check Connector as it's only used for my efan, but while replacing things I might as well make that look pretty.
#326 | |
Finally got around to fixing the wiring. It's starts up and idles quite nicely. Next things on the plate, recharging the A/C, making a cold air intake box, deciding if I'm doing anything else with the body...and paint.
#327 |
Rotating Assembly
Gratz. It must be a relief to clear that hurdle
#328 |
I know it has to feel good to clear that hurdle! Congrats man.
#329 | |
Yeah, not knowing how badly off the burned up wiring was stressful. But I got to learn more about reading wiring diagrams by getting my hands dirty, I fixed my problem and the engine is purring quite nicely.
One other thing I forgot on my to-do list. Converting a P/S rack over to manual.
#330 | |
le sigh
The engine is working great until my efan runs with the manual switch turned on for an extended period of time. I was out driving today in stop and go traffic. There is still something not quite right with my thermoswitch in that IIRC the Starion switch is a 195 on switch. It is not triggering my efan until 210ish. Either that or my Prosport temp gauge is not accurate. So I got nervous that I was at a stop light and my temps were rising above 200 and I flipped my manual switch on. Things were fine for a couple of minutes and then the engine starts sputtering, it's wanting to stall out and I barely get it into a parking lot where it does stall out. I don't find any burned or blown fuses, all the wiring looks fine. After it sat for 5-10 min I start the engine up and everything is fine. I move it to a better parking space. The thermoswitch has the fan blowing on its own. I never had this kind of problem before melting wiring and replacing the main relay. I'm not sure where to check next. The alternator?
