Old 04-06-2008, 10:29 PM   #1
-xlr8planet-
-xlr8planet-'s Avatar
FD gauge dash: how the hell this thing works?
Im halfway on the schematics.
Could someone PLEASE sumarize for me what works using the cars ECU and what works just out of a sender?
pleeeeease
Old 04-07-2008, 12:15 PM   #2
mazpower
Rawr Bearclaw
mazpower's Avatar
Oil pressure, coolant temp, and fuel level are all sending unit driven gauges. The speedometer, tach, oil level light, coolant level light, and all other lights are driven by the ECU INSIDE the gauge cluster.
Old 04-07-2008, 02:04 PM   #3
-xlr8planet-
There´s an ecu inside the gauge cluster? Besides the load ecu and the main ecuż?
from the schematics my conclusion was:
Oil pressure, coolant temp, and fuel level = analog signals, easy to do
Tach = signal from coil
Speedometer = signal from gearbox, goes to the ecu and then to the dash
Pics... easy to read schematics or idiot notes would be great
I need a "GAUGE CLUSTER FOR DUMMIES" kinda thing,...
Old 04-07-2008, 03:12 PM   #4
mazpower
Rawr Bearclaw
mazpower's Avatar
What exactly are you trying to do?
Old 04-07-2008, 03:39 PM   #5
-xlr8planet-
Im installing an FD interior in an FB
Old 04-07-2008, 05:37 PM   #6
mazpower
Rawr Bearclaw
mazpower's Avatar
Ahh I see.
What you need to do first, is get the cluster to power up. Here's the FSM schematic for the cluster (you may have this already):
http://www.rotaryheads.com/PDF/3rd_g...ng_Diagram.pdf
Go to page 46.
The connections are pretty self-explanatory. The tach connection is either the blue/yellow (4C) or yellow/blue (3F) wire, I can't remember for sure. The oil level light won't come on unless the wire is grounded, the coolant level light (and buzzer) WILL come on unless its grounded. If you are going to disable that, ground it to one of the ground wires in the cluster.
The ABS & Air Bag lights are going to come on. Best thing to do is pull the bulbs. When you pull the bulb for the air bag light, the cluster is going to make a faint series of beeps when you turn it on. It will take about 5 seconds or so for the beeps to stop and it will do this every time you power up the cluster. After a while you stop noticing it...its not like a coolant buzzer.
Old 04-07-2008, 07:53 PM   #7
-xlr8planet-
Thanks man. I really appreciate it
I still need the dash harness, that will simplify my life...
Old 04-08-2008, 09:38 PM   #8
-xlr8planet-
At least Im making progress
I´ve identified several things and acording to the 94 FSM and the 81 FSM the water temp sensor output is the same
So I just have to give that gauge 12v + ground + signal and I already identified what conector is what
Old 04-08-2008, 10:47 PM   #9
-xlr8planet-
Old 04-09-2008, 08:48 AM   #10
-xlr8planet-
FB values
Old 04-09-2008, 09:01 AM   #11
-xlr8planet-
