Old 06-11-2010, 11:43 PM   #76
Turbo SA22C
Turbo SA22C is on a distinguished road
Excellent and informative thread.
Are the installation vids complete?
Series 2 SA22C, S5 13BT, Full 3" Exhaust, Streeport, Haltech ECU
Turbo SA22C is offline   Reply With Quote
Old 07-03-2010, 04:28 PM   #77
dudemaaan
dudemaaan's Avatar
Here's the youtube channel for the updates on the kit I made for Rob. http://www.youtube.com/user/emerciv
I've made a couple more kits for members on the other forum, once pics and stuff are placed I'll be sure to post them here for people to see.
Old 02-14-2011, 01:49 AM   #78
Sideo
Sideo is on a distinguished road
thanks for the writeup
Sideo is offline   Reply With Quote
Old 02-14-2011, 12:38 PM   #79
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
lol nice video title
http://www.youtube.com/user/emerciv#p/a/u/2/cTKtRiRk7Sk
Old 03-29-2011, 07:40 PM   #80
dudemaaan
dudemaaan's Avatar
Im Running a coupon code through April 4 for anyone interested in getting a kit. $25 off using the code 25OFFWATER. Www.wannaspeed.com the front page has the kit listed.
Old 08-10-2012, 06:51 PM   #81
Flash
Flash's Avatar
Flash is on a distinguished road
Hey,
Did you ever end up trying to run that inline adjustable check valve? Or did you nix it since you'd need a higher flowing nozzle?
Thanks...
Flash is offline   Reply With Quote
Old 08-17-2012, 09:25 AM   #82
ROT8WA
ROT8WA is on a distinguished road
Originally Posted by dudemaaan View Post
Just universal aluminum piping 2 1/2". I welded them all myself and saved money that way. Make sure to get T bolt clamps to hold the couplers in place, regular hose clamps suck. Pick the most direct route to reduce bends and increase response.
drewrey2004,
One other thing mate, If you can't afford the "T" clamps. Just add a couple of lips on the ends of the pipe so the hose clamps don't slip of as it is very effective.
On a side note with regards to the air temps you are seeing. waters latent heat of evaporation is of course at 100 degrees Celsius so taking into account your high air temps you would actually be getting the water to vaporize a lot sooner. It still sounds like an unsafe condition and I would not care much to be a guinea pig trying something like that out... Better to invest now rather than when your motor needs to be rebuild.
ROT8WA is offline   Reply With Quote
Old 08-17-2012, 10:29 AM   #83
dudemaaan
dudemaaan's Avatar
Originally Posted by Flash View Post
Hey,
Thanks...
No I scrapped that idea. Since the adjustable check valve has a spring that restricts the flow the water pressure would be reduced by whatever amount it was set to. That would not only reduce my total water flow but also reduce the atomization. If the valve was set to 8 psi and Im running 28 psi of boost pressure my effective water pressure would then only be 20 psi.
